tamiya porsche 959 question
will a Tamiya Dyna-Run Super Touring Motor fit into a tamiya porsche 959 will the front and back white platic parts fit the motor tight and then fit into the car i know a technipower and technituned and a 540 silver can(only one type i found) will fit into the tamiya porsche 959 the Tamiya Dynatech 01R will fit and the Tamiya Dynatech 02 wont fit but if the Tamiya Dynatech 02 motor if u some how fit the rings to the motor tight it will work the rings that i got where loose on the motor i have here just to let every one know here the Tamiya Dyna-Run Super Touring Motor will not fit the porsche 959 unless u make up the white rings to fit the motor thanks for your help every one i'v got some pic of the motors that will fit the tamiya porsche 959 some of the motors will be bit loose on the white rings but u could used wire heat shrink these one type that goes really hard like a rock tamiya 540 50032 silver stock motor will fit tamiya dyantech 01 tamiya dynatech 02 tamiya technipower tamiya technituned motor silver stock motor link www.ebay.com.au...1438.l2649 lipo battery for the porsche 959 and yes will fit the car easy its hard to find a battery for vintage that will fit www.ebay.co.uk/...:rk:1:pf:0 |
Last edit: by spannerman3.
Moved to the Technical section
silver stock motor in the tamiya porsche 959
but u have to bend the pins out a little and ad new wire took me a few goes to get it right cant wait till i build the car with the silver motor yes will run slower but it cost nothing to change the motor out and don't have to buy brushes for 50 or so lot cheaper to run |
