I'm looking to pick up a Juggernaut and I found one without a body. The original body is part number 335173 and is discontinued. However, I was always under the impression that the F-350 body from the Juggernaut was the same body used on the F-350 Highlift. The Highlift body is avaiable and is part number 9335455. Does anyone have any idea what the difference is? I can't see anything obvious.
Found a thread here: www.tamiyaclub....uggernaut/
The Hi-Lift body has much larger wheelarches. F-350 has also rear taillights, Juggernaut has not.
Thanks for the information, that's exactly what I needed to know. Makes sense that they would enlarge the wheel arches for the highlift to make room for the suspension movement. I think this is good news for me. You can't really put a Jugg body on a Highlift because the tires wouldn't fit, but you can put a Highlift body on a Jugg because the wheel arches are irrelevant. This means I should be able to just pick up a new body and it will look pretty good.
