Servo connector question 4 years 7 months ago #56383
Finally found my old RC parts box and I have several Futaba servos with the prongs sticking out style connector is there an adapter to plug these into the modern common receivers?
Servo connector question 4 years 7 months ago #56384
Futaba servos still come with the tab on the side of the connector to this day. To use with a receiver using flat connectors, just cut off the tab with a sharp knife. No adapter necessary. It is only there as a polarity indicator to keep you from plugging it in backwards.
Servo connector question 4 years 7 months ago #56385
Like said blackbird cut it. Be careful if you want to use a vintage sanwa receptor. Polarity is inverted. Same matter with some ko rx.
Servo connector question 4 years 7 months ago #56543
Hi there,
I am old enough to remember the type of connector you are talking about. This was the Futaba G style connector. You can convert them to the new J style by changing the plugs over. Check online for the plugs, the ones I have used do lack the extra piece sticking out so you need to be aware of what way you plug it into the receiver but they work just fine in the end, Futaba always made good quality servos they have never failed me.
The following user(s) Liked this: Pintom
Servo connector question 4 years 7 months ago #56544
Thank you!!
Servo connector question 4 years 7 months ago #56546
Hi there,
Nor mine. Some used in my mrc rabbit dad.
I only have problems with my futaba attack sr grey transmitters.
Time to create page: 0.102 seconds
