Hi fellow Tamiya enthusiasts,
Having collected quite a few Tamiya vintage models, particularly with the ORV chassis, I never came across one that uses the 2nd hole in the alu gearbox plates (the first one being used for the battery cover pin). Why is it there? Is there any model that uses this 2nd hole? What for? Thanks guys, I appreciate your insights. Cheers MetalMaxx |
Hey awk, thanks so much. Lowspot however points out in the comment section "the batterymount was a common self made hop up from the spring parts of the front axle - the white pieces are part of the front axle damper mechanism"
I understand from that, that one just used this 2nd hole for s home made battery mount hop up, but that does not necessarily mean that Tamiya planned it like that? What do you think? |
I think lowspots Brat ist a pre production sample, the battery door is also different. Imho Tamiya changed the battery door and the locking system before the SOP to the well known pin solution.
Last edit: by awk.
IDK if that preproduction battery door would have been backwardly compatible with a cased hump pack, possibly that was the reason for the change.
The pin "solution" guarantees future business due to it getting lost |
