Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67554
HiWill the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet if I purchase the Hotshot E part triangle hub? My concern was the axle maybe a different length.Thank you in advance.
Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67555
Yes it should.
Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67558
Thanks for reply.
Another member has told me, whilst they would fit the axle is too long.
Alternative  is to purchase Nova wheels / adapter and fit the Hotshot tyres to them.
Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67561
Just use spacers between the wheel and the wheelnut to take up the extran length of the axle.
4mm washers or a piece of 6x4mm tube should work. Also a M5 nut can be used as a spacer.
Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67562
Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67563
You can use a 850 bearing to
Will the Tamiya Hotshot Rear Wheels fit the Tamiya Hornet 2 years 9 months ago #67565
Time to create page: 0.142 seconds
