Do any happens to know a brand of grafitti remover that's available in norway, that is plastic safe, polycarbonate safe too would be even better!
Reason beeing, the one I was set on is not recomended on any plastic at all. Lars, do you use any grafitti remover at all in your builds? Richard |
I don't. I use caustic soda on hard plastic and brake fluid on polycarbonate. Also tried not to fuel, which destroyed older polycarbonate but was ok on newer. My experience is that removing paint on polycarbonate/Lexan is a gamble each time... Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
A couple of Norwegian sellers of graffiti removal chemicals. (I have not checked if they are ok with plastics.)
www.pervaco.no homemaker.no/va...ensemidler www.norengros.n...gr-3000-5l Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
