I def agree with you ! Proud owner of the Bruiser Family
Well with a few Immanent arrivals I felt the need to sort out my shelving Not happy at all with my temporary solution I started by cutting some threaded rod, Some 130x80x25 steel U channel and bolting some 30x30 angle alloy to 2 pieces of the U channel ( 1 at each end ) I hung the threaded rod from the existing shelving brackets and BAM new display
it will be a rc?
OK,
My guess is the trailer needs to grow a bit to accommodate the boat outside the door And???? From somewhere out in the wilds of central Ontario.
Well spotted, Yes it is for the boat outside the door Bu the trailer needs to shrink a bit for a better fit ( 300mm all round ) The Original trailer was a bit stuffed to I picked this on e up reasonably cheap, Of course I need to fit the Boat to the trailer and being a CAT makes it even more fun If you can't fix it with a hammer, you've got an electrical problem mate
