Looking forward to Peter Maddison doing the voiceover
The walls on the back and sides only have a depth of 50mm so I have to make it work, Having 12mm of ply on the outside also helps with the insulation If you notice the front wall is full depth so I was able to use the thick insulation in there In saying all of that I am lucky that It doesn't snow here If you can't fix it with a hammer, you've got an electrical problem mate
My mate is building a small apartment atm, and the newest rules states it has to have 10" of insulation I hope that does the trick when it is below -25, here, rare but it can happen.. I bet your garage will be perfect |
Melbourne's In winter, average temperatures range from 6.5 - 14.2°C (43.7 - 57.6°F)
Thank you for your kind words, I am working very hard to make it so If you can't fix it with a hammer, you've got an electrical problem mate
It must have been in the stars that a big Tool Shop had a sale today They just happened to have a couple of little tools that I wanted for the new shop A pedistal drill, Thicknesser and a drill bit sharpener from another shop I will be adding wheels to the big stuff as well as a base for the thicknesser
Attachments: |
Last edit: by AndyAus.
Niiice Andy
Thanks Flo Here is a little time lapse of today's progress
