Looks very '90's HPI chassis with an old Duratrax esc. What's it say on the receiver?
Tamiya had copied it for the TT01 isn't it?
1:10 VH-32 Electric RC Car
Four wheel drive system with shaft drive Fast Speed: 60km/hr (40 mile/hr) Equipped with high speed motor and bevel gear differential gear box Transmission shaft enables the car steadier, light shock & fast speed while running High capacity 7.2V NI-CD rechargeable battery Front /Rear bumper provide good protection against accident impacts Equipped with axletrees to reduce friction of the components and to run smoother and faster Front and read double wishbone suspension Coil spring shock units Sturdy ABS monocque frame Mid-dhip mounted battery 3-step speed controller included Semi-assembled chassis Built-in front and rear bevel gear differential Double wishbone arms with adjustable width Oil filled dampers Top quality chassis |
My TT01 has the Enzo too.
My sparrohawk is very similar too. More with the brushless set |
