Rear axles 6 years 2 months ago #48155
Hi
Can you get shorter rear axle rods that hold the wheel on for the lunchbox
Neil
Rear axles 6 years 2 months ago #48156
I think no. Or you need to modify a set.
Rear axles 6 years 2 months ago #48163
Ok thanks I was thinking if i could cut the end off that goes in the gearbox tap the shaft and screw some nuts on the end and lock tight them on
Neil
Re:Rear axles 6 years 2 months ago #48165
Whats the plan for the shorter axles, use standard hex and different rims or just less width?
Re:Rear axles 6 years 2 months ago #48168
To use different rims and less width I got some frog hex adapters but the rims just stick out to far
Neil
Time to create page: 0.110 seconds
