Ball connector question. 6 years 1 month ago #48788
What is the size of the ball connector on the coupling on the grand hauler?
Mine has snapped and unsure on size for replacement.
Ball connector question. 6 years 1 month ago #48816
If you don't have the manual you can get a PDF from www.tamiyausa.c...uler-56301 (click on the "manual" link) ... from your description part# BE6 appears to be it - tamiya call that a 4mm connector....part # 50590 will be a lot cheaper than buying a whole "E" bag, assuming it's correct ...
Ball connector question. 6 years 1 month ago #48821
Had a look. BA20 it is listed as, which funnily enough is 4mm.
Thanks.
Time to create page: 0.110 seconds
