My M chassis builds 8 years 7 months ago #35342
Construction of the engine is now complete - lots of detail on the front end + a basic fake gearbox on the back... in hindsight I probably should have found some size specs for the engine, measured the engine bay & done some careful calculations - but doing it all by guesswork has worked out fine :D
Ideally I need to change the cap head screw on the fan for something a tiny bit shorter, but the only reason the V8 doesn't fit perfectly in the Pumpkin engine bay is because I need to cut a proper transmission tunnel :D :y:
The following user(s) Liked this: Dam
My M chassis builds 8 years 7 months ago #35344
:woohoo: awesome work Jonny. You just missed the a/c compressor . alucinating same the alternatives fan is present. :y: :y: :y:
My M chassis builds 8 years 7 months ago #35345
Spoken (in quotes) like a true bearded monkey. Looking great. :y:
My M chassis builds 8 years 6 months ago #35462
lovely Ford truck build projects. Nice HD images.
My M chassis builds 8 years 6 months ago #35498
Just finished painting & reassembly - the gearbox is held on with Blue Tack at the moment as I'll need to separate it later :)
The following user(s) Liked this: Edou, AndyAus, Al
My M chassis builds 8 years 6 months ago #35499
Can you do that last picture again, with a puddle of oil beneath it. :laugh:
If it wasnt for that cuttingmat you could have fooled me :y: :y: :y:
My M chassis builds 8 years 6 months ago #35500
:woohoo: Awesome Jonny. :y:
My M chassis builds 8 years 6 months ago #35504
Wow Jonny! excellent weathering. :cheer:
I think you may have outdone yourself here... :y:
My M chassis builds 8 years 6 months ago #35557
Tiny motor & gearbox ... specs are 1000rpm @ 12v, 16mm OD...
Wiring, homemade brass assymetric weight & mount added:
Holes Dremelled in engine ...
... motor installed:
Even with the body jacked right up, this is how much I'll have to cut off the back & base of the engine to make it fit over the front suspension ... that seems very wasteful & I'd rather build another engine - but in the meantime this projects going back in a box due to lack of enthusiasm :(
My M chassis builds 8 years 6 months ago #35561
:( A lot of us are enthusiast for you Jonny.
Time to create page: 0.483 seconds
