Thanks for testing blackbird
Good to know they are 1.9" which I had a suspection of The solution would be either gluing a pair of tires together, or just narrow the stock Lunchbox/GF01 wheels depending if you want to use hex adapter or the orginal Lunchbox one.. Section the Lunchbox wheels should be easy, just use a lathe or a drill/hacksaw and cut to the width you want and the eiter sleeve with a tube or a strip of styrene. I've found out the CB Avante rear tires are 99mm in diameter which is 16mm shorter than Lunchbox. Should lower a stock Lunchbox and improve the handling (I'm currently running 2.2" with stadium truck tires on my re-re, and that have too much grip actually now and then... )
The CB tires are pretty stiff, and they are also toroidal (doughnut shaped), not flat bottomed. I think stretching them would be a problem. I suspect you could physically get them onto 55mm wheels but it would look very strange.
They are actually the equivalent of 2.2". I will be interested to see if you guys can find a way to get them on a LB or MP. You'll lose some of the bounce but gain traction.
Nice! Low ride lunchy.
