The idea would be to make a Hot Rod starting from a front and rear end of a Sand Scorcher Mk 1.
then I took a re-release body to which I removed the superfluous parts with a 5 mm plasticard sheet I made the bottom. With 2 mm screws I secured aluminum strips to the bottom. Then I covered them with 1 mm plasticard That's what I set the front axle to the chassis |
Here is a beautifull project.
Hey man!
That looks amazing, great start, I will be following along This reminds me of a couple of cars I saw at Bug Jams I went to back when I had a fairly serious VW addiction in the late 1990's, very cool indeed!! My hat is off to you as well for having the " guts to cut " I just have never been able to do it to a body shell re-re or otherwise, unless I was grafting pieces together to fix one back to original. I just need to work on getting over my fear I guess, what with re-re bodies still available. Keep up the great work!! From somewhere out in the wilds of central Ontario.
Oh!!! This is cool, count me in as a follower of this project
Wow!!!! nice and clean.
Nice idea
Got to sya though, exposed servo horn as the lowest point of the car seems like asking for trouble |
