Oh come on, there are lots of other possibilities, off the top of my head these are things you could/should try: - keep the servo in a similar position but lifted so the steering rod runs parallel with the frame rail; - ditto but lay the servo on its side; - similar to what you already have but higher & forward of the firewall (and/or put a "power bulge" in the firewall) - lose the OE servo saver & fit the servo pointing backwards, with a modern saver; - similar, but with the servo further back, you don't need all the space unless you're putting a Merlin in there. - similar, but with the servo even further back & remodel/sacrifice some of the sump, it's not like it's a real engine & you need the oil; What you've done there is stop at the first kludge that worked and called it a "solution" |
yes maybe as you say there are many solutions.
The engine is definitely bulky, the solution I have found should not be problematic, the car is high on the ground and then it will mount slick tires, suitable for smooth surface use, so no possibility of damage to the servo. I also prefer not to use modern parts.
Hey guys,
I really like where this is going now . Was that the 1/12 Fiat dragster kit that donated the engine?? I have seen some nice builds of it too. I agree the steering setup leaves a bit to be desired but it is neatly executed and for a flat track car damaging it shouldn’t be an issue. I think for off road there might be better solutions but that is why we post things here with our friends…to get their input and inspirations too . We all have our own way of doing things don't we It reminds me of a problem I dealt with many years ago on a VW dragster we were running. Originally I had built the chassis with a side shifter linkage but after the first season we knew it wasn’t working out, So I came up with the crazy idea to mount a vertical gate shifter in the center of the rail and couple it directly to the transaxle shift rails….hmmm….without going into great details, space was very tight so my only real option was to run a couple of the shift rods under the floor of the rail, not the best idea but the other option was to bore a hole through the drivers groin! For some reason he was not interested in option 2 Due to the dragster aspect of the car it was never a problem. We just had to be aware they were protruding when we were loading and unloading the car. The new shifter solved all our shifting problems too. I like the upside down servo installation too, how thick is that floor sheet? It looks fairly stout. My question is are you going to brace the joint where the frame rails meet the roll bar or is the floor thick enough to hold it? Great work man, it is giving me lots of ideas…can’t wait to see the rear slick tires on it!! From somewhere out in the wilds of central Ontario.
Last edit: by oldwilly.
The engine comes from the Lindberg Exterminator 2 kit on scale 1/8.
It may look great, but the dimensions are suitable for this model The floor is often 5 mm, the aluminum lists are fixed directly to it giving the overall robustness needed. Regarding the steering to me it seemed a good idea, of course, all things can be improved, but that works and I'm satisfied. Thank you for your consideration. |
If That work, keep it. It is your project. If you need advices, all we are here. You make a good job.
Of course, the forum serves to confront and increase its knowledge. Critics and suggestions are welcome.
