Lunchbox Custom Build 5 years 4 months ago #53140
So lets Talk a bit about me and my LB project . My Name is Tobi i am from Germany 37 years old . I work i the paper industry and play Guitar in a christian metalband called Ancient Prophecy .
When i am not at work have time with my Family or am on the road playing gigs i go to my hobby chamber building Tamiya cars since i am 7 years old.
This here is a LunchBox wich i got for a steal price , already with oilshocks and Junfac dampermount and gearbrace.
When i stripped the paint caus i didnt like the purple i noticed that the body was not in that good condition as it seemed .
so what to do ..... right make it a custom build enough words here we go.
The following user(s) Liked this: Gripper107, Toyz123
Lunchbox Custom Build 5 years 4 months ago #53141
As you can see the front right corner were broken off and the pre owner put backlights in it made out of a bycicle reflector. that was not done very good and he used a lot of putty.
i had to plasticweld the corner back on
and then started to strip the paint down with breakfluid.
Last edit: by Tobiwahnknobi.
Lunchbox Custom Build 5 years 4 months ago #53142
The purple came of quite well but underneath it the preowner used a green and some sort of alloy or zinc spray it sticked really good to the body so i decided to keep it and just give it a sand. Now you can see the big holes he made for the backlights and put them in with putty .
They needed to be closed .
Lunchbox Custom Build 5 years 4 months ago #53143
Using Uhu Allplast wich works really good on the Tamiya Hardbodys i closed the holes and used maskingtape to mark the next things to be happen.
Lunchbox Custom Build 5 years 4 months ago #53144
And the there was the point of no return . look what i "saw" next
The cuts were made and then i started to close the cabin and started closing the backlightholes and give the whole thing some first putty.
Lunchbox Custom Build 5 years 4 months ago #53145
After some sanding smoothing sandig i realised that the strange paint the preowner used somehow made the body brittle there were thousand of micro cracks in the surface , so i decided to do a more rough detailed surface then i had planned. Then my Camera quit and i lost some steps in the build, so i can only post some wide steps. The panels are made of polystyrene sheet , The Rivets are made using woodglue mixed with talcumpowder wich is applied with a injection syringe with the needle cut flat on the tip.
The following user(s) Liked this: stingray-63, Gripper107
Lunchbox Custom Build 5 years 4 months ago #53146
Uhu, wieder was gelernt ;)
Getting the popcorn out this is going to be interesting. :)
The following user(s) Liked this: stingray-63, Tobiwahnknobi
Lunchbox Custom Build 5 years 4 months ago #53147
The first result then looked like this
Lunchbox Custom Build 5 years 4 months ago #53148
Had a lot of fun bashing her arround but i decided to get the things a bit further . Had something in my mind the whole time and so i decided to give her a new mock up .
First i decided that she needs some proper backlights that suit the theme that was going around in my head .
The new Crew also arrived and gave everithing a first check.
Lunchbox Custom Build 5 years 4 months ago #53149
To get a bit of the themed look the grille had also to get a new look, and i started to build the onterior and the workplace for the new crew.
So far the two KS2O units seem to like it ;-)
Time to create page: 0.242 seconds
