Hello, I am in the process of recreating a Ranger. My first RC car, sadly sold long ago.
Need info on the body mounts. Found info on the front mount, so that should be ok. Anyone have info on the rear mount too? Would love details on the bar height, and how thick the pressing on the middle is. And of course measurements on the hex pin. I will be modifying a Blackfoot body, so measurements on the bar 'cradles' under the rear bed would be nice too. Saw the 'faking a ranger' topic, great info there! |
Welcome on board. I did a ranger tribute to. But Jonny retro can give you a real answer.
You should have marks under the body for holes. I stabilized the body on the bar with uretan foam.
The following user(s) Liked this: Oldtimer50
Hi there, I got those mount lying around and can measure them tomorrow.
Oh, that would be awsome. Thanks |
Thanks, Found a few pictures online myself, but not the measurements to recreate one.
If you have a caliper and the time. I guess the bend radius in the corners are the same as the Sand Scorcher and Buggy Champ bars, so that I can find myself. |
Hi, this is on UK eBay at the minute. Al
Thanks, it's listed as UK post, but I asked the seller if he posts abroad.
It seems a bit used for a shelf queen, but it might be fixable. |
Rear hoop: pressing in the middle is 4mm (0158") thick, overall bar height is 79.15mm (3.116"), the centres of the 3mm hole are 3.47mm (0.137") from the ends ... will endeavour to get the rest for yo at some point. Can't give you the measurements for the bar cradles as mine were guessed at/what seemed to fit/work. Took photos of the hex part & annotated dimensions:
I would think a bit of a rub over with wet and dry paper and a polish with something like autosol and that will come up a treat.
