Welcome, Guest
Username: Password: Remember me
TOPIC: 8x4 MAZ/MA3 535A from Lunchkins
8x4 MAZ/MA3 535A from Lunchkins 9 months 1 week ago #55701
Screenshots from Spintires for future reference ...
8x4 MAZ/MA3 535A from Lunchkins 9 months 1 week ago #55709
Thinking about the cable reel, 50mm diameter is about as big as I can get on the Unimat, and as I don't fancy hand sawing a bar that big I was limited to precut 50mm or 100mm lengths (I couldn't really justify buying a bigger 7x14" lathe and/or bandsaw for just this one piece).
I've come up with a back-of-a-cigarette-packet design (neither particularly square or symetrical :whistle: ), it's fairly chunky as TBH the less I have to take off the billet the better ... however I did worry about how much wire rope (1.5mm diameter Bowden cable) I'd be able to get on the reel, 2.5m being about the amount that seemed a realistic optimum.
I found a hose drum capacity calculator at https://www.copely.com/tools/hose-drum-and-reel-capacity-calculator/ , and plugging in values from my sketch (d = 1.5mm, core = 26, flange = 50, traverse = 32) suggested I'd get 20 to 23 _metres_ of "hose" on my reel.
This seemed a lot, so I wanted to check the maths...
flange - core = 14mm, / 1.5mm = 9 layers
traverse of 30mm / 1.5mm = 20 rounds per layer
core circumference = pi * d, and will go up 3mm per layer
			d	c
layer	1	3.142	26	81.692	20	1633.84
	2	3.142	29	91.118	20	1822.36
	3	3.142	32	100.544	20	2010.88
	4	3.142	35	109.97	20	2199.4
	5	3.142	38	119.396	20	2387.92
	6	3.142	41	128.822	20	2576.44
	7	3.142	44	138.248	20	2764.96
	8	3.142	47	147.674	20	2953.48
	9	3.142	50	157.1	20	3142
		sum				21491.28 mm
... or 21.49m.
I just have to make it now ...
Last edit: by Jonny Retro. Reason: typos
8x4 MAZ/MA3 535A from Lunchkins 9 months 1 week ago #55725
Had hoped to have started on the winch drum, but the still aluminium hasn't arrived so I made some keepers to help locate & protect the swing bearing on the rear axles, and also started on the boxing in on the underside of the chassis. The rear end has a lot of layers & reinforcement as I'm planning to fit a towing eye in that area :)
8x4 MAZ/MA3 535A from Lunchkins 9 months 1 week ago #55732
Aluminium finally arrived, facing it off went smoothly enough ...
... as did drilling all the way through on the pillar drill. I didn't get very far before the traverse action on the top slide was seizing up. Nothing was obvious from the outside & cleaning & lubing what I could wasn't helping, so I completely dismantled it & cleaned in the U/S tank ...
Back on track, but after several grabs & motor stalls I killed the PSU & speed control. It looks like it's just fuses are the problem, but they are odd types & I can only get them by mail order. I'll probably have it up & running again by the end of next Wednesday, but I've got to question the wisdom of continuing to push the Unimat so obviously beyond its capacity :(
8x4 MAZ/MA3 535A from Lunchkins 9 months 1 week ago #55735
Wow, looking good man!
Ya, that's a big piece of alloy for a unimat and before I had anything bigger I would do such things too. I do recommend you support the free end with a center in the tailstock, It will really help with the digging in problem. And of course take small bites. The mate I sold my old unimat too called me up shortly after he got it because he broke one of the chuck jaws when he did a similar thing turning a longer fat piece of brass unsupported, expensive lesson learned. I think there is an old machinists formula for such things something about 1 1/2 times the diameter and you need to support it, or something like that.
The unimat is very capable, there is a riser kit for turning even bigger stock, folks have built some amazing things with them. :)
Despite their obvious design flaws I am still very much a fan of them, for the price and size it is just amazingly handy to have one :y:
8x4 MAZ/MA3 535A from Lunchkins 9 months 1 week ago #55742
Thanks Oldwilly, I can get a live centre in the tailstock to reach with the current setup, which should at least let me finish the end I'm currently working on ... once I've charged up a couple of batteries. :)
I have the official headstock raising block & made a block to lift the toolpost the same amount, but I'm not aware of anything available to lift the tailstock on the early models :(
8x4 MAZ/MA3 535A from Lunchkins 9 months 4 days ago #55767
One advantage of using Anderson Power Pole connectors ...
Tail support meant I could finish the end I was working on & start digging out the useful bit, however the diameter was too great to get any part of the slide under it, so had to do the rest unsupported. I gave up chasing the flaws as every time I was getting somewhere, it dug in again. Changes from the "design" were counterboring to 8mm so it would fit the gearbox output shaft :whistle: and reducing the depth of the load area. As i've decided to use 1mm wire (for flexibility) it still means the capacity is over 16metres.
8x4 MAZ/MA3 535A from Lunchkins 9 months 4 days ago #55768
Can't order any more parts for a few days, so I thought I'd start on some of the detail bits that aren't dependant on doing anything else first - this is as far as I got yesterday:
(I cheated a bit because the backs won't be seen ;) )
8x4 MAZ/MA3 535A from Lunchkins 9 months 4 days ago #55769
Nice!
8x4 MAZ/MA3 535A from Lunchkins 9 months 3 days ago #55774
Fuses for my DIY Unimat PSU arrived - 20mm, 15A fast blow ceramic (2.93 GBP for 5) & 10mm 6.3A slow blow glass with axial leads that need soldering in (3.20 GBP for 3).
Both types installed & PSU reassembled, lathe working as intended again :)
Moderators: Jonny RetroAndyAus
Time to create page: 0.877 seconds
