Knight Customs "Wild One" Sand Rail project. 2 weeks 3 days ago #75374
Nothing too exciting but the roof mount tabs on the cage seemed a little lost Measured up a brace and asked Bezerk to cut out while doing a piece for the Maxxum ff
The following user(s) Liked this: caprinut, stingray-63, Al, 1972 LeMansGT Jim, GToddC5
Knight Customs "Wild One" Sand Rail project. 2 weeks 3 days ago #75381
I hope that it will have a long thin antenna with a triangular flag
Knight Customs "Wild One" Sand Rail project. 2 weeks 2 days ago #75390
I do have a spring base Tamiya antenna whip somewhere 🤔 Nice idea Flo :)
The following user(s) Liked this: stingray-63, GToddC5
Knight Customs "Wild One" Sand Rail project. 2 weeks 1 day ago #75392
Knight Customs "Wild One" Sand Rail project. 1 week 6 days ago #75403
Going with Flo's suggestion I restored an old SRB type whip to use for a sand dune marker flag, Was pretty bent but straightened out enough Polished a frog resistor mount bracket for a whip base plate which of course fitted the original WO resistor mount location on the cage
The following user(s) Liked this: caprinut, stingray-63, Al, 1972 LeMansGT Jim, Ducksnuts, GToddC5
Knight Customs "Wild One" Sand Rail project. 1 week 6 days ago #75404
After realizing my mistake with the initial servo install I have been procrastinating finishing it, Sucked it up and completed the steering setup today
The following user(s) Liked this: caprinut, stingray-63, Al, 1972 LeMansGT Jim, EddyCH, GToddC5
Knight Customs "Wild One" Sand Rail project. 5 days 22 hours ago #75457
Feeling Exceedingly grateful after receiving a custom driver figure from Knight customs for this project, As you can see it has a helmet which pays tribute to the Wild One 😁 Took some measurements and Shortened the steering column, Now I can put the driver in and out with ease 😊
The following user(s) Liked this: caprinut, stingray-63, 1972 LeMansGT Jim, GToddC5
Knight Customs "Wild One" Sand Rail project. 4 days 21 hours ago #75468
Decided to make a shifter for this, Used the same rod as the steering shaft and thread one end to M4 and tapped the other to M3. Machined an old alloy pinion for the base and tapped to M4, Machined the hex off an M3 ball stud then bent the rod to the angles bringing it close to the driver. I used real world principals where driver doesn't have to move his hand far from the wheel to reach the gear shift 😁
The following user(s) Liked this: caprinut, stingray-63, 1972 LeMansGT Jim, EddyCH, GToddC5
Knight Customs "Wild One" Sand Rail project. 4 days 14 hours ago #75471
Lookin great!!
Knight Customs "Wild One" Sand Rail project. 4 days 11 hours ago #75477
That shifter looks awesome!
Moderators: AndyAus
Time to create page: 0.126 seconds
