58016 Sand Scorcher Resto 7 years 2 months ago #42103
I've never seen SRB rims crack like that. :y: :evil:
The spokes are usually cracked from over-tightening the screws , but not the entire rim! :ohmy:
Oh, where did those "external rings" come from?
Last edit: by larbut.
58016 Sand Scorcher Resto 7 years 2 months ago #42126
I know it's strange, it's the first time i see rims cracked like that.
Those rings are from the outer part of the rims...they were holding with the paint, i picked them up at the bottom of their DOT3 bath.
58016 Sand Scorcher Resto 7 years 2 months ago #42136
Last evening i started to assemble the tires. I had to replace the tires because they were too cracked. So, i ordered re-re ones. My thought was to rebuild this SS using exclusively vontage spare parts, but honestly until now this is the most expensive resto project i ever had ! Even the Bruisers/Mountaineers i've done until now were not as expensive as this one !
Luckily the decals are present as the door handles...and i still have to find a radio box (mine is broken) for a fair price !
I already got me a new front bumper, both mirrors (those tiny little things were just expensive as h**** :evil: :evil: )
Anyway, as i tried to fit the tires on the rear repaired rims, the outer ring broke off again :angry:
So i'm still figuring out how to repair them avoiding to use re-re ones !
In the meantime i could assemble the front ones with the new tires the mailman brought:
Hopefully i can do the lettering tonight.
thanks
58016 Sand Scorcher Resto 7 years 2 months ago #42139
I think that you used CA bond and it's not the better for the rims. (it breaks like glass. You should better use a translucid bi compound glue like araldite.
58016 Sand Scorcher Resto 7 years 2 months ago #42141
Yeah, i might try your suggestion :y: :y:
Thanks Flo
58016 Sand Scorcher Resto 7 years 2 months ago #42142
jt'en prie ;)
58016 Sand Scorcher Resto 7 years 2 months ago #42143
The black terrodon could be better but you'll must repaint the rims . Use a slow drying araldite. It is harder than the fast drying. ;)
58016 Sand Scorcher Resto 7 years 2 months ago #42145
I'm also convinced that the black 2 components would be a better solution.
The point was that i wanted to keep the slight yellow white colour of the rims making it look as vintage as possible.
58016 Sand Scorcher Resto 7 years 2 months ago #42146
:unsure: You need translucid araldite. It is enough hard.
58016 Sand Scorcher Resto 7 years 2 weeks ago #42762
Hi all,
Very small update on this one.
I've done the tire lettering after assembling the wheels.
Wheels assembled:
With lettering done
Last edit: by Manotas.
Time to create page: 0.163 seconds
