Nice work indeed!
Tip to get bolts with threadlocker unstuck. Use a solder iron and hold the tip on the bolt head. The heat from the solder iron will heat up the glue and hopefully loosen it enought to get the bolt out Same trick can be used to get a counter sunk bolt to sit flush in plastic bits. Just hold it long enough til the plastic melts and pull the bolt in as long as needed. A edge around the bolt head is formed due the plastic been forced away from the bolt. Just cut with a knife when finished after cooling down |
Thank you ! I'll keep that in mind for my next resto ! Proud owner of the Bruiser Family
Installed all the electronics in the radio box.
Now installed on the chassis I'm still waiting for a resistor, one was missing, and the new motor with the pinion. That's the reason why all the wires are not connected yet. On the other hand I received the small M2x5mm hex screws I ordered for the rims. They match perfectly ! Proud owner of the Bruiser Family
Very nice work, Manotas!
(and I envy your radio box lid with two tabs!) Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Thanks Lars ! I might have radio box lid with the 2 tabs if interested , I'll confirm this later on Just hit me up Proud owner of the Bruiser Family
What are the 2 tabs?
those two bits on the lid pointing forward.
And are they rare?
Those are tabs mentioned Flo : It seems that many brake off, I suppose due to miss operation of the owner while trying to open the lid without removing the front cab. I've seen a few where those tabs are off. Proud owner of the Bruiser Family
