No. The Egress has the traditional split ring with a screw. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Yep those are a first on the TFE later they came with the blue sleeved dampers. think atm those are more rare than the MR oneway. OP-111 How about some hopups? |
Very cool hopups!
Hollow carbon shafts is just completely over the top Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
The following user(s) Liked this: Snappy1
Last edit: by larbut.
I did it after several build. But I trimmed it with the antenna wire |
Last edit: by stingray-63.
Depends on the position of the receiver. |
It bothers me that even though there are 4 sympathetic angles you could have gone with, the arrow you used to illustrate your OCD lines up with neither the framing of the image nor the orientation of the chassis. Ps not entirely joking |
