Richard's freebie, 58051 The Fox. 5 years 1 month ago #54265
All flat.
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54383
  • caprinut
  • caprinut's Avatar Topic Author
  • Away
  • Moderator
  • Moderator
Back to this project...
First I had to clean my workbench as it was a mess.
Good enough :)
First I sanded most of the extra epoxy away, then cut out the damaged hump in front of driver and also the bit at the side over the battery area.
The hump on top pf the chassis got a bit of styrene and the side got a bit from the spare rear part of the upper chassis glued in and sanded.
I use JConcepts tire glue and baking soda as a activator (helps a lot!!) In my case it's Dr. Oetker Bikarbonat Natron
During sanding the styrene bit I got a bit carried away and happen to dremel down the bodypost in the process.
Can someone measure for me how tall the body post stay is from the flat surface?
You can also spot I do miss the antenna holder for the right side.
My plan is to first replace the missing flat part as I've done, then graft the antenne holder from the spare upper chassis to this.
This is mainly down to I don't have the correct size styrene in stock atm, and I think I can get away with cut off the orginal holder from the spare bits.
A test fit
I will avoid sanding down all the way to the letters on the chassis.
Up to now I have mainly used 240 grit paper, but will go over to finer grit and fill the remaining cracks with filler.
Only thing I have right now is Tamiya putty, it shrinks too much for my liking.
I do have fine Milliput tho.. Hmmm :whistle:
For this rebuild, the chassis will take most of the time I reckon..
The following user(s) Liked this: stingray-63, Sam
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54386
What the work!
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54395
  • caprinut
  • Away
  • Moderator
  • Moderator
Todays progress...
A bit more sanding and I made the missing antenna holder.
Cut out the one from the spare chassis top.
The metal antenna is the only one I got atm.
Need to buy another one.
And I finished painting my driver today.
I really suck at this, even with magnifying glass, which did not help at all as I lost the depth of my vision when trying to paint.
Shaking my hands don't help either.
I may cover the body in flat clear as the colors is straight out of the bottles.
I really need a new camera too.
It tends to white out everything and make it a tad blury in every program.
Camera was new in 2011 and must have taken 4-5k pictures, so for £180 or so, :y: I think it has been good value for the money
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54401
What a great old school style restoration, Nice job :) Yes painting those little driver head's with a shaky had is a bugger but part of the build ;) Could I suggest that the driver fire mask really needs to be a light colour to help blend it to the eyes ;)
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54409
  • AJB
  • AJB's Avatar
  • Anytime Baby!
  • Anytime Baby!
The flat surface is on a slope, but it's pretty much 1cm:
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54419
  • caprinut
  • Away
  • Moderator
  • Moderator
Thanks Andy!
Just the tip I needed!
Do you paint the flesh first or the white?
Richard's freebie, 58051 The Fox. 5 years 3 weeks ago #54420
  • caprinut
  • Away
  • Moderator
  • Moderator
Thank you very much :y:
Richard's freebie, 58051 The Fox. 5 years 2 weeks ago #54500
Thanks Andy!
Yes the white then the flesh :) tamiyabase.com/...t?start=20
Richard's freebie, 58051 The Fox. 5 years 1 day ago #54710
Richard, I found some fox spares. Are you still missing spares? :)
Time to create page: 0.186 seconds
