The France was different. 26 and 41 were generic bands and 72 for flight.
Hmm strange maybe the original builder was into flight had all the 40mhz gear and decided to utilise it!
I got some gear from Hong Kong a while back and didn't realise that 40MHz is apparently pretty standard there...
Edit - I think it all depends on what frequencies the country in question frees up. I had to figure out if it was even legal to use - some of the higher 40MHz bandwidths are actually reserved for the military here.
OK I'm in the UK is that where you are? |
I remembered there was an issue getting crystals to properly work with it...
Edit - This was a nonsense post, later realising that this particluar transmitter is synthesizable and only needs a receiver crystal... |
Thanks @Al I now finally have compatible crystals & transmitter and I was able to try it out and everything seems to work OK. But as you say it looks like it needs some minor adjustment as when I switch it on the drive wheels rotate momentarily for about half a dozen rotations and then stop. I looked on the ESC and there are two adjustment holes in the casing, one that says "Neutral" with a letter "B" on left end of the scale and a letter "F" on the right end of the scale. The second adjustment hole is marked "High" with a volume type scale increasing in a clockwise direction. I assume the "Neutral" control is the one to adjust to control the wheel movement on start up? If I am correct in my assumption then what is the "High" adjuster used for? Thanks in anticipation. |
The high is to adjust the max speed in full throttle. You can adjust it. When you need speed or run time.
Thanks I'll have a play this weekend 😁
"B" is for Back or reverse, and "F" is for Forward.
Adjust this so the vehicle do not move. "High" is adjusted for the top end, aka full speed. Hold the throttle and adjust till it does not gain more speed. That is like adjusting 100% movement on modern radios as radios these days adjust the speed controller as there is simply no adjusting knobs on modern speed controllers as they don't need it.
