I restored a 959 and I found the shocks pretty acceptable for a touring car, although the volume and travel is much too small for any off road use. That's OK, because you'd be crazy to drive one off road anyway (ignoring Tamiya's ads to the contrary). |
The tube is there for volume compensation. There is no bladder in the head end of the cylinder like other oil dampers, so when the rod compresses there is less volume available for fluid within the cylinder. Without somewhere for it to go, you'd get a hydraulic lock. The tube effectively swells to add volume, so it needs to be flexible enough for that to happen. This particular damper has a semi-balanced rod (it extends to both sides of the piston but isn't exactly the same diameter) so the volume doesn't change all that much. I don't think it has any significant impact on the damping; that should still be driven by the piston. This piston doesn't have any holes in it, the damping is controlled by the difference in size between the OD of the piston and the ID of the cylinder. Very unusual dampers. Attachments: |
I wrote about it pretty extensively in my 959 topic (portions quoted below). It helps that I work on hydraulic actuators for a living so I understand most of this stuff.
You yourself are an engineer.! Now the oozing knowledge and understanding makes even more sense.
I work for a major sustainable energy distributor, technical field support to industrial plants. Bluegoodness
An update on the MCI tyres, Unfortunately the quality is poor and they split even as you are just washing them in warm soapy water to remove the print residue. I was given a full refund on them and as they were part of a bulk order I wasn't out on shipping. I have ordered some GB-01 tyres sets to try instead, As this will be a runner they don't need to be OG but would have been nice.
The following user(s) Liked this: stingray-63, GToddC5
Hi Andy, I’m gutted for you on those tyres.
Did Nathanial say this might have been a one off ?? Thanks for the update.
