The best thing you can do to remove old gasoline on engines is tu dissasemble it and put in a recieptient with gasoline in it and wait for a few min's. Other solution: I use petrol for cleaning mechanical parts of my motorcycle, the one used in petrol lamps for example... This will remove anything (with a bit of patience) without damaging aynthing like rubber seals or any other gaskets with the benefits of slightly lubricating the parts Btw, great Job you're doing there ! Proud owner of the Bruiser Family
Last edit: by Manotas.
That's a shame oh well guess you get to build a frame then I want to build a frame to make 1 of my 1/8th monsters into a sand railer so if you build yours, I can see how to do it
Oh well, at least you've cleaned it up to make it more saleable If you can't fix it with a hammer, you've got an electrical problem mate
wont SG Leopard parts fit this? they look very similar
