Last edit: by silvertriple.
As per my experience, I don't think it will be useful add extra strength:
I'm still due to print a sample in PLA (I'll print all the PETG Marui parts before I start the builds), as I'd like to be able to verify everything is fine before publishing the parts, which would also allow for pics. If everything is fine, I may publish some parts today or tomorrow in Thingiverse... Edit: Impression in progress I buy kits to built and ru(i)n them
Printed with settings to make it quick. The print is not perfect, but for a test, that is making it.
Dimensions are fine, but the place where there was contact with the supports makes it slightly difficult to engage... I will need to review the top of the part to reduce the thickness, as looking at some pictures provided by Optimaforever (the guy who has designed the gearbox cover including reinforcement of the shock towers), there won't be enough room to fit both parts. I need to reduce the thickness to 3 mm, potentially 2 (A package with those parts, bumpers and roll bar is on the way)... All that said, it is still quite promising. I may need to find out how to remove support in a specific area of the print (this is something I never done before). With each new attempt come new learnings. I buy kits to built and ru(i)n them
Published some parts today on thingiverse
www.thingiverse...le/designs The last one, the bumper fixation reinforcement, still require work. I may also have to modify the first part I published as well, so they can work together (today, it's either one or the other)... In short, more thinking, more work I buy kits to built and ru(i)n them
The first part I published on Thingiverse has been modified so the shock tower brace wich enclose the shock tower should now work with the rear bumper fixation reinforcement. I also modified this one for two reasons:
Few printed parts incoming straight from "The Optima House"
Beside the body shell, that is completing my quest for the 3 Marui Hunter chassis.... And while the reviewed part did print properly as there was a filament jam (need to replace the nozzle), I decided to test the parts with the first print I did... Accordingly to his test, I can already confirm V2 will be compatible with the parts from "The Optima House". The compliant part will be in published in Thingiverse within the week. I buy kits to built and ru(i)n them
