Yeah... Sorry, I did not found any English equivalent press article... :-D At some point, I'll try to do an English summary of this piece... Finished the unbuilt of the Galaxy.
I also have thought about the weak points of the chassis. They don't seem to be the same whether it a Galaxy or a Hunter. On a Hunter, they tend to break on the front area, and it seems that doesn't happen on a Galaxy. I believe the top structure on the Galaxy is participating to this. And my son start to bug me about a Galaxy rather than a Hunter... Another idea came in my mind due to those points: i'm starting to think about a printed roll cage, in a Samurai or Javelin spirit to go on the Hunter chassis. The fact modern radios are allowing to remove the radio lid would help to have something quite streamlined, and with an interesting design :-D I didn't start the cleaning work or the rebuild activity today, as the plan is to go fro a run with my son in the afternoon. I may do some building or cleaning activities tonight, however.... I buy kits to built and ru(i)n them
Did some cleaning of parts in the afternoon, after a run on track with my son and friends earlier.
The M4 metric machine thread screws got me thinking tonight. Since I have 2 broken chassis not usable as too much broken to be usable, I decided to do some test with some M4 screws. I used a M4x10 machine thread screw instead of the 4x12 auto tapping screw: - screwed right in the hole in tubes, it breaks the tube. Made 2 like this. Two broken tubes. - add lubrification in the hole (ptfe or grease) before screwing the screw in, and it seats perfectly without any breakage. I confirmed this in multiple holes (5 of them). In short, I have a replacement for the 4x12 screws missing in the kit. It's even better than this, as it also work in the damaged thread as the root of the screw is larger than the root of a tapping screw: It's the perfect solution for those holes where the tapping screw was turning free... Now I only need to find about 40 M4x10 machine screws and a another complete set of M3x10 screws, as there will be 5 Marui cars from this project:
After the cleaning, I decided to start the red galaxy. I need some room, so the best way is to get the parts that are not in a box waiting for other parts to join a châssis and become a car...
As planed when I set my bid on the red Galaxy, I swapped the chassis. As all the parts beside the chassis were in perfect state, that will be easy... I will just put the pics with not much precision, as it is essentially the same as the Galaxy RS except I paid attention to the operation sequence, and the blue part are actually red in this one, with a nice 550 size Marui 360RS motor... I actually built it to the same point as the Galaxy RS and remaining steps will be parallel builds... State as of now Both cars will use a modern ESC and a FS-A3 RX. They both have been built with a reinforcement link between the shock towers, as I intend to run them times to times... I buy kits to built and ru(i)n them
Very nice Marc
Unexpectedly found new wheels for both the Galaxy and Galaxy RS
This will be perfect for the shelve. I'm not sure I will dare to put those wheels in the dirt... But who knows, they were designed for this. The fact is that all the rims I had with the cars have some damages due to the runs, and it is not so nice. My usual way to deal with this is one set for the shelve, and one set for the run: modern tires may be more adapted than good old gums to run, and they will probably resist longer... In any case, I'm not sure I'll resist longer to finish the Galaxy builds I buy kits to built and ru(i)n them
Yeahhhhh pretty gold find.
thats an impressive find, a silver set too! As for running them, thats a hard one, personally one of my 'projects' it to machine my own set of rims (I have a lathe, just lack the time) and run with more modern tires that are easily replaced, keep the originals for display.
Yeah, I think at the end I'll print rims with silver PLA filament to run. Either with glued tires (such as the Kyosho ones) or the such as the Hornet ones (they are the same dimension, they just need a different format for the internal ring and the lock : this should be feasible easily).
My son even told me he is fine with Hornet wheels for his onw Hunter (I'm still trying to find something better, but that would be ok to order a set of complete Hornet wheels, drill center to 5 mm and add a proper adapter design to do the work with those and the 5mm axles... I buy kits to built and ru(i)n them
Since months ago, when I saw the cluster and did the checks on both the Marui Hunter and Marui Galaxy RS manual, I had evidences there was parts unused on both Galaxy and Hunter cars. I thought a lot about this. My assumption is that there was a plan with a 4 friction shocks buggy with this chassis...
I found out some webpage in wayback machine about the Tokyo Marui cars today. The website is now closed, but it still appears on the archives: The RC cars of Tokyo Marui – Vintage Dirt-Burners (archive.org) There is on this page what I think is the evidence of the 4 fiction shocks Marui car based on the Hunter/Galaxy chassis.The Hunter prototype was using a Rough Rider like body. And it did have a air scoop at the rear end and no monoshock. Near the rear tire, you may distinguish a friction shock So basically, on the Hunter/Galaxy cluster, there is part of what is required to build a Hunter prototype :-D I buy kits to built and ru(i)n them
Last edit: by silvertriple.
