i was thinking of keeping it nitro. i found a cool engine for it
www.hobbyking.c...r_Car.html |
just bought the brushless motor and gearbox. once i get it running i will get the rest
wooooooo just need to wait for them to get here click here to see a ROUGH idea of the motor mount i will make |
Last edit: by zephyrin.
Hey Zephyrin, good work you're doing here However the Jeep body that you have picked up for it (free I hope )although the wheelbase will fit your warhead ( within a couple of mm), will need quite some work to get it there. Because of the low bed in the back and the lack of front window you may find that all the hard work you put into fixing and fitting it, will be undone the first time you flip it (especially since its a hard shell) I also have a little warhead project on the go and have the same jeep body which I was planning to fit, but have decided that the Jeep body was more suited to a scale project (in the future) I ended up with a stadium truck shell and with not too much fuss, I was able to fit it up nice best part was it only cost $24 delivered from an Aussie seller Also be careful about fitting larger diameter wheels to it, as this will upset the gearing and put more load onto your gears and drive shafts good work anyway, looking forward to seeing your progress Andy....
Attachment 006800x532.jpg not foundIf you can't fix it with a hammer, you've got an electrical problem mate
Last edit: by AndyAus.
