Try on ebay
The attachment appears to be a .doc file which I am inclined to not open...
Perhaps you could insert a file with an image format. Edit - yeah okay, not the same one... Source
I can see the alloy mount that you are searching for but unfortunately also cannot find any extra information for it, I doubt it has it's own part number. I can only suggest having one made, Do you have access too or a person who has access too a lathe? If you gather all the required measurements it will be an easy part to machine.
Cheers Andy. If you can't fix it with a hammer, you've got an electrical problem mate
Attachments: |
Last edit: by AndyAus.
I hope he has a lathe too, A mill is good for flat surfaces If you can't fix it with a hammer, you've got an electrical problem mate
I don't understand where is the matter. Isn't it the same as the egress one? The chassis is the same as the egress on the avante 2001 in size.
