Super modified 11t motor 10 months 1 week ago #75592
  • Girox
  • Girox's Avatar Topic Author
  • Anytime Baby!
  • Anytime Baby!
Awesome thanks! Will check this out as well!
I’ll let you guys know!
Super modified 11t motor 10 months 1 week ago #75593
  • Girox
  • Anytime Baby!
  • Anytime Baby!
Thanks for all the help! Will check all these out asap then let you all know.
you guys are great!
The following user(s) Liked this: GToddC5
Super modified 11t motor 10 months 1 week ago #75596
  • Girox
  • Anytime Baby!
  • Anytime Baby!
Found the Traxxas XL 10 new in box from the uk. As soon as it arrives and I hook it up I’ll let you guys know!
thanks and cheers!
Super modified 11t motor 10 months 1 week ago #75604
Try the mtronics viper. It's unlimited in turns from what I remember. And it has the backward speed.
I had no luck with mine. Catched fire.
The following user(s) Liked this: Girox
Super modified 11t motor 10 months 1 week ago #75612
Super modified 11t motor 7 months 2 days ago #76754
You'll want an ESC designed for brushless motors, as the 11T motor is likely brushless based on the description.
dino game
Super modified 11t motor 7 months 2 days ago #76756
Info from the Motor section of this site:
Motor description:This is a high performance motor designed for use with electric R/C touring cars. Equipped with 11 turn rotor, ball bearings, brush dampers and heat sink. Motor case with high power magnet efficiently dissipates motor heat. Timing adjustment, disassembly and maintenance is possible. Use with large capacity amplifier suitable for 11 turn motor. Tamiya C.P.R Unit cannot be used.
Motor data
Type: Brushed
Timing: Adjustable
Maintenance: Rebuildable
Turns: 11x2
Normal voltage: 7,2 - 8,4 V
Torque: 250 g/cm at best efficiency and 7,2V
RPM: 38000 rpm at no load / 7,2V
Brush orientation: Stand-up
IG_tamiyaddiction
Super modified 11t motor 7 months 2 days ago #76757
  • Girox
  • Anytime Baby!
  • Anytime Baby!
Thanks guys. Yes i know about the technical specs of the sp 11t and so as I was advised I got a traxxas xl10 esc. Still waiting to run it and plug it all in because I also bought a super Avante for the whole build around the engine and esc which I still have to start…
Will let you all know how it goes. Also I’ll try a 7.2 v battery then probably use an 8.4
thanks a lot everyone
