Golf Mk1 Manual Speed Controller 4 months 2 weeks ago #77268
  • Thaezix
  • Thaezix's Avatar Topic Author
  • No Guts No Glory!
  • No Guts No Glory!
Ok, here is an image of the speed controller disassembled in order. Whats happening is that the sweeper arm for forward and reverse is getting super hot instantly. I feel that maybe something is missing from the assembly that is causing a short? It will go forward and reverse but only as I near the ends of the resistor.  I also took a picture of the wiring to the underside of the speed controller.
Last edit: by Thaezix.
Golf Mk1 Manual Speed Controller 4 months 2 weeks ago #77306
Hi,
I think you have the sequence of the parts wrong.
The "flanged pipe" should go on the top, just below the nut, with the flange pointing up.
None of the washers should be there, if I recall correclty.
Disclaimer,:I take this from memory only, and looking at similar MSC...
Golf Mk1 Manual Speed Controller 4 months 1 week ago #77314
  • Thaezix
  • No Guts No Glory!
  • No Guts No Glory!
Thanks for the help larbut. I will try your suggestion!
Time to create page: 0.087 seconds
