Re: Modding a DF-01 bathtub for slop free steering 11 years 8 months ago #12677
Aaaargh the suspence is killing me... :S
:laugh: :laugh: :laugh: :y:
Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12688
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Undercowl coming right up... :cheer:
First some more details of the reinforcement - after sanding :
Almost right, only a minimal amount of extra putty needed (and glossy paint of course) :
And now for the undercowl! :blink:
I wanted to paint this to run the FRP chassis so I made a bit of an experiment from it.
A MkI TBG isn't a fantastic quality item so trying out some stuff can't hurt...
First up - how much can I sand it before it starts showing after paint?
Maximum 600 dry sanding paper I think... inside smoothens out :
Outside looked pretty good too after a first glance :
It might have actually been better if I stopped at this point.
But then I noticed some scratching...
So I put the undercowl in DOT4 and did some finer sanding :
Only to find out the inside was fine and the scratches I had seen were mostly "natural" lines on the outside. :S
Still I cannot stand something like this so I sanded the outside up to 1500 wet :
Still needs a polish. I think I've found the perfect stuff for that...
It's quite affordable but shipping's just a female dog.
No other real source to get this outside the US as far as I've seen.
Anywho, you can even see how much the undercowl shrunk - leaving a second imprint of the holes. :huh:
So I may just spray the outside... and put it on this bathtub!
Tapping some thread into the otherwise unused holes would do the job :
I'll only do that on the front. I'll fill up the rear holes and use velcro there so I still have battery access. :)
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12689
What you need is a Tardis, will save you a lot of hassle with experiments like this ;)
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12699
  • Edou
  • Hopping Mad
  • Hopping Mad
Maybe I could borrow your Evo for that... :lol:
In a way, this experiment is the next project's time machine. :blink:
Best to try stuff out on items that are imperfect to begin with. :)
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12827
  • Edou
  • Hopping Mad
  • Hopping Mad
Second round of putty for finer smoothening :
Now it's at a level I can find acceptable - you gotta either know or have a really good look to spot that it's been altered.
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12834
  • Edou
  • Hopping Mad
  • Hopping Mad
Some more work done on the undercowl too - reinforced alu tape to cover up the holes :
Filling it up with resin on the other side :
Then sanding... and since I didn't really get it smooth (poored on too much and need epoxy), some putty for the finish :
More sanding :
Still not that smooth :
But I won't go the extra mile here because it is actually there to get damaged instead of the chassis itself.
Here's the inside painted after I did the bits of tape with permanent marker first :
Maybe I'll rough up the surface next time as well because paint doesn't stick that well on it...
I went looking for some more self adhesive velcro (at "Blokker") but they don't carry that stuff permanently. :(
I'll have to find some for attaching one side of the undercowl to the chassis.
Soon a last post in this topic with the steering parts and undercowl on! :cheer:
Then I'll move the story back to the "customization quest".
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12930
  • Edou
  • Hopping Mad
  • Hopping Mad
Okay, a bit of a bump in the road... :S
The step screws used on a bathtub chassis are 3mm and I've been using 4mm here so they fit the bearings in the steering.
Disassembling a few times has eroded the threads, giving the screws too much room to wiggle.
So I think I'm gonna have to fill them up with molten bits of a sprue tree and redo the threads.
A new terrain of restoring for myself...
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12941
How about trying to fix the thread with something like a HeliCoil?
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12942
  • Edou
  • Hopping Mad
  • Hopping Mad
Thanks, that's the term I needed. We're even on the "Pokemonish". :lol: :y:
Something like that was the first thing that popped into my mind but it was too vague to go on a search...
I will now though! Seems like just the solid mech approach I'd strive for. :)
Edit - I only hope the bit of plastic is big enough to fit it...
Otherwise I'll have to see if 840 bearings exist at all.
Re: Slop free DF-01 tub steering - plus TF undercowl! 11 years 8 months ago #12943
  • Edou
  • Hopping Mad
  • Hopping Mad
Hey guys, do you read this ad the same as I do?
Inner diameter is 4mm
Total width 5.4mm
Length 8.1mm 6mm
Thanks! :)
Btw - 840s do exist but they're half a mm thicker, which will give all kinds of new trouble... :S
Time to create page: 0.182 seconds
