4wd Chassis identification. 3 years 7 months ago #62062
  • korreka
  • korreka's Avatar Topic Author
  • Being nuts is NEAT!
How did you fabricate that, korreka? I'd be interested to see the steps...
You need:
* 1 rod of 4mm o.d. and 1 tube of 6mm o.d (4mm i.d.) , both in aluminum. --> available in home improvement retailers (Leroy Merlin,..)
* epoxy glue (or cyanoacrilate glue)
* 2 pins (or a 2mm or 2.2mm steel nail)
* a drill, 2mm bits, a saw, a file.
1) Cut the 4mm rod to the required length. Also cut the 6mm tube to get 2 rings:
2) Glue the 2 rings to the rod with epoxy. Then drill it with a 2mm bit.
3) Insert the pin usin a workshop clamp and a nut (you can glue the pin with epoxy too).
4) If necessary, file the ends of the dogbone a little:
Done:
5) Check the vibration or eccentricity of the shaft:
The following user(s) Liked this: caprinut, Edou, stingray-63, TamiyafanTrieste
Last edit: by korreka.
Time to create page: 0.115 seconds
