Any compressor recommendations? 7 years 2 months ago #42784
I run a 50l sealey compressor, but I do use a mini spray gun for main shells and not just air brushes.
However I do connect it to a sealey airbush via the standard rattle can edapter. I had a double sided thread that for perfect into the cap and 1/4 compressor fitting. I run a small regulator/water catch in between this.
I would definitely get a cheap 24l as above, yes it's noisy but lasts quite long until you it fills back up again. Depends on what space you have also I guess.
Last edit: by Purple_rob.
Any compressor recommendations? 7 years 2 months ago #42786
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Thanks for sharing. I think I need to do quite a bit more research on the subject. :unsure:
This would be quite important for air dusting desktops too...
Any compressor recommendations? 7 years 2 months ago #42788
Yep. Water+paint= bubble spots..... you need to have dry air for a nice paint.
Any compressor recommendations? 7 years 2 months ago #42794
To be honest as I run the whole set up rarely and I empty the compressor tank regularly in compression, I don't seem to have a problem.
In my opinion/experience you shouldn't need one for a little air blasting of a keyboard or even motherboard. I would make sure that compressor had a regulator (which I think is standard) as they really do blast the air out.
Time to create page: 0.108 seconds
