Database could include Pinion and gearing details... 2 years 11 months ago #66228
Glad to be to any help
I found this handy calculator for gears www.technobotso...lator.html
Database could include Pinion and gearing details... 2 years 11 months ago #66230
Just thinking.... One of the motor pinion was 20T, the question would be then how to assemble a motor pinion and a gear with the right number of teeth (48T, or equivalence in a different mod, using another pinion on the motor side)...
Brain is still working :-)
Database could include Pinion and gearing details... 2 years 11 months ago #66441
As I did sort out some DT03 parts inventory, I had a ball diff that I never mounted on the DT03 as well as the universal shafts going with it... I just check and the diameter of the diff is more or less the same as the 60T in 0.6 mod from the Hunter, but it is in 0.8 mod. Looking at a calculator, to have approximately the same diameter as the 20T 0.6 mod in .8 mod, it should give 17T...
I guess I have now to look into spur gears in .8 mod to see what I can find. The DT03 is 19T so that one is already out of the possible choices...
Is there somewhere a chart with the spur gears data (number of tooth, mod - I'm thinking about Tamiya first, but may look beyond Tamiya)?
Thanks...
Database could include Pinion and gearing details... 2 years 11 months ago #66444
Database could include Pinion and gearing details... 2 years 11 months ago #66482
Well, I would be more in search of the gears used in our Tamiyas, with the number of teeth & mods. To me, it just seems wrong there is no list of components of each hop ups and spare parts, including this type of details...
Time to create page: 0.115 seconds
