Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47048
Time to fit the upper and lower shock mounts and reattach the now hornet style axle
Please note the screw fitted in to each axle mount is only there to hold the spring in position during fitment, they are then removed.
Axle movement was a bit tight n sticky so very minor trimming was required to the center pivot, after which it was spot on :y:
Last edit: by goldfish999.
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47049
Now fit the shocks n see how it looks
Not bad if i say so my self :)
The difference is dramatic on tiltability
Only problem now is the body dont quite fit, i know im going to end up playing with the shock positions at a later date so will leave body mods unti the very end of the project
Extra screws n bolts required so far: 2x BA2 3x21mm (self tapper), 4x BA3 3x8mm , 2x BB1 3x12mm, and some M3 nuts n bolts
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47050
Buddy it sounds very good.
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47051
Looks Awesome so far , waiting for the drive results , when it turns out like u wish i will go for that to.:y: B)
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47057
Thank you :)
It could be a while before a test drive as there is still the front end to do and the rear end is going to have another total reconfiguration as my bits from Ansmann have finally turned up, have a look here: tamiyabase.com/...yyyy#47011
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47088
So ive had some time to start the front end, all stripped back down to components and shell
These parts not needed for mod so put to one side
Parts to be used again
Parts required for the mod (minus shocks, as they have not arrived yet :( )
4x 5mm ball connectors (50592)
4x 5mm ball end connectors (50875)
4x screw pins (9805756)
Ansmann aluminium brace (K93418)
Ampro 20mm offset hornet bottom arms, hub carrier and mount (045001-20)
Some M3 threaded bar
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47089
That's promising.
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47090
First thing to do is prepare the bottom arms n hubs for assembly
The green arrows were all drilled out to 3mm, the red arrow was originally also 3mm, but i was not happy with the sideways movement on it, so drilled it out to 4mm then pressed in a 10.5mm length of 4mm aluminium tube (3.1mm ID) the blue arrow, problem sotred :)
Time to assemble and fit :)
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47091
I am glad to see your custom. Very nice.
Re-Re Grasshopper full suspension mods and a few more bits :-) 6 years 4 months ago #47092
Now for the fun part, getting the top mount which is designed to be fitted to a hornet to fit the hopper, im trying to keep the hopper looking like a hopper as much as possible, so would like the body to attach as it should to the chassis using screws thought these holes in the body.
I will have to compromise slightly on the geometry and lower the mount 3mm to hopefully enable the body to fit with minimal external change, the mount would usualy mount to these holes using a couple of self tappers, no good to me as i need thes holes to mount the body
Luckily once the ball ends are fitted to the mount there is some thread out the other side, which i can use to alternatively mount it :) using some threaded nylon bits n bobs ive got
Cut to the right length n fitted to mount
And that is the mount ready to fit :)
Time to create page: 0.275 seconds
