Day one, UPS dropped off one large and one small box. I've never seen a Tamiya branded shipping box so it's a good one save and store things in.
I was on my way to work when the kit was delivered so I took a couple quick pictures and brought everything with me. I pawed through the boxes when I got to work. To be continued....... |
Day two,
Screw bag A; First thing, binding a receiver, centering two servos and on my hacked GT3B programming channel 3 trim rocker for shifting. Step one is building up the steering and shifting service savers. Step 2, attaching servos to service mounts. It's best to leave the servos a little loose till their mounted on the frame rails. Step 3, prepping cross members. Step 4, attaching cross members, servos and rear suspension mounting plates. Step 5, installing rear axle bump stops. The instructions want them painted black but I'm leaving them chrome. Step 6, front suspension mounts. Step 7, building shocks. They don't actually do anything but they look good. Step 8, mounting front shocks and soring shackles. That's the end of screw bag A. Stay tuned for screw bag B. |
Thank you meister
The following user(s) Liked this: Dasbeermeister
A truck build thread !
Looking forward to this Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
A hauler build is orgasmic....
Oh man, this build thread is going to be good. Already bringing back memories of my King Hauler.
How did you manage to use the Hitec servos? I thought they had a 24 tooth spline. I've run into this problem a couple of times with Hitec. |
I was wondering who would pick up on them. Their just place holders while I'm waiting for some Futaba S3003 servos to be delivered. |
Last edit: by larbut. Reason: fixed the quote
Day three
Screw bag B and C Step 9, Attaching front springs and lower shock mounts to front axle. Step 10, Attaching front axle assembly to the frame. Steps 11 and 12, Building up spindles, the tie rod and mounting to front axle. Step 13, Assembling and attaching rear springs. Step 14, Building up the rear differentials. Steps 15, 16 and 17, Assembling the rear axles. Screw bag C to be continued shortly.....
Last edit: by Dasbeermeister.
Shocks are more realistic than on the king hauler and ford aeromax. And trailers to.
