58046 FAV 6 years 1 month ago #49113
Nice work Al. Use an airbrush for the paint ;)
58046 FAV 6 years 1 month ago #49115
  • Al
  • Al's Avatar Topic Author
  • Hog Heaven
  • Hog Heaven
Many thanks Flo.
It’s coming together quite nicely.
I don’t have an air brush, but I think you could be right if I’m going to do this car justice.
Hope you’ve had a good weekend.
58046 FAV 6 years 1 month ago #49117
Thanks. A quite sunday. I am sure that you will make a pure fav. Next week I will be able to take the wild one.
58046 FAV 6 years 1 month ago #49124
  • Al
  • Hog Heaven
  • Hog Heaven
I’ve been trying to get more organised with my spares recently. I’ve got some neat little plastic boxes with little compartments, ideal for sorting everything into size and type of screws etc.
So I went through my boxes of nuts, bolts and screws and have got everything present attached to the car.
And I’ve even found the correct tyres in amongst the spares boxes.
I’ve got some spare motors so I just need to see if I’ve got any screws long enough to attach it.
3x27 mm. More hunting.
Last edit: by Al.
58046 FAV 6 years 1 month ago #49125
Sorry Al. No screws but I have that for you.
58046 FAV 6 years 1 month ago #49126
A quick note about your gearbox :) As you can see the bearing sits lower than the casing and there is a ?1mm gap ;) You need to put a shim in the bearing cup before the bearing so that it sits up. If not, when the gearbox is under load there is to much room for the diff to push apart and it will slip and grind up your gears :ohmy:
Last edit: by AndyAus.
58046 FAV 6 years 1 month ago #49128
  • Al
  • Hog Heaven
  • Hog Heaven
Looks awesome in black.
Cheers Flo, I’ll PM you tomorrow to discuss further.
Awesome mate !!!
58046 FAV 6 years 1 month ago #49129
  • Al
  • Hog Heaven
  • Hog Heaven
Cheers Andy, I appreciate that, I should have read the instructions properly.
Many thanks.
Last edit: by Al.
58046 FAV 6 years 1 month ago #49131
Many thanks.
Oh you wont find that in a manual ;) It's just knowledge from running these :)
58046 FAV 6 years 1 month ago #49132
  • Al
  • Hog Heaven
  • Hog Heaven
Many thanks.
Hi Andy, thanks for that, I thought you were referring to this section of the instructions.
But thanks for the tip, I've got a Wild One waiting in line. No where near as much work as this, but it's great to know for when I tackle the gear box on that.
Much appreciated.:y:
Time to create page: 0.179 seconds
