How the Sand Rover should look. 3 years 3 months ago #64400
You gave me the idea to rebuild a chassis I have in spare if I have all parts
How the Sand Rover should look. 3 years 3 months ago #64404
  • Al
  • Al's Avatar Topic Author
  • Hog Heaven
  • Hog Heaven
What chassis are you going to use Flo ?
How the Sand Rover should look. 3 years 3 months ago #64407
I have several spare parts of my last hb resto. I have to see but still have the main tube. But no body...
How the Sand Rover should look. 3 years 3 months ago #64409
  • Al
  • Hog Heaven
  • Hog Heaven
Hi Flo, original or re-release ?
If original I might be able to help.
How the Sand Rover should look. 3 years 3 months ago #64410
Original chassis but worn. I will list all parts I have.
How the Sand Rover should look. 3 years 3 months ago #64430
  • Al
  • Hog Heaven
  • Hog Heaven
Let me know what your looking for Flo.
Last edit: by Al.
How the Sand Rover should look. 3 years 3 months ago #64454
  • Al
  • Hog Heaven
  • Hog Heaven
I bought a cheap reamer the other day. I didn't know about these until I saw Jonny post about some he'd just bought.
It was new to me, but perfect for adding the rear body mount holes on the Sand Rover shell.
This is a really neat way of doing this.
Next job will be to start sanding the rough parts and tidy the back end up. I was using filler to get the bulges on the inside at the back of the shell, this definitely still needs work.
How the Sand Rover should look. 2 years 11 months ago #66671
  • Al
  • Hog Heaven
  • Hog Heaven
Times been short recently, but I grabbed half an hour on Sunday.I’ve dug around in my spares and found some original tyres for this. Not the best, but not the worst either, that I’ve seen on a Sand Rover.I had also picked up a couple of MSC’s recently, so after buying the control arm this is all coming back together from what was left overs.  I stuck in an old Futaba servo because it’s the only I had spare that would match the servo horn.
Last edit: by Al.
How the Sand Rover should look. 2 years 11 months ago #66672
  • Al
  • Hog Heaven
  • Hog Heaven
And with the body popped on.
Next jobs will be strengthening the body where it fits onto the 2 black plastic body mounts.
And the front body mounting point needs re- instating in some way on the chassis tub.
I think once the weather sorts itself out, I’ll get some primer on the body. That’s going to show up a myriad of errors.
The following user(s) Liked this: stingray-63, jord001, smsdalleisback
How the Sand Rover should look. 1 year 5 months ago #73133
really nice work :D
Time to create page: 0.144 seconds
