Marui Hunter and a Galaxy RS too :) 2 years 9 months ago #67670
Published the stl files of my reinforcement for the shock towers of the Marui Hunter/Galaxy chassis
You can find them here:  Marui Hunter/Galaxy Rear suspension reinforcement by silvertriple - Thingiverse
The following user(s) Liked this: stingray-63, Al, jord001
Last edit: by silvertriple.
Marui Hunter and a Galaxy RS too :) 2 years 9 months ago #67676
Saw it on FB looks great. Nice one.
Regards
Lee
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68017
Another broken chassis with parts arrived today. I had a quick look:
  • complete transmission in proper state at the exception of the motor pinion
  • motor support
  • front gearbox cover in proper state
  • screws
  • front suspension in perfect state
  • front wheels with a bit of cleaning required, but tries are in good state
  • steering rods and part of the servo saver is there
  • front bumper is in good state
  • the chassis itself is broken on the rear side. There was an adaptation of a two dampers with a metallic bridge, and it was fixed within the remains of the shock towers but the remains did not survived nothing remains there, the chassis is almost flat within this area. Almost all the tubes holding the threads are highly damaged.That being said, the part where the idle shaft goes is in perfect state. May need to think, because this chassis front looks in perfect state. Maybe something to do...
  • rear axles seems longer than original ones. I suspect it is linked with the shocks which were added on the rear train, as they take much more room than the original links
  • I have one additional Hunter wheels and what appears to be Super Hornet or GH2 wheels. The rim diameter is bigger than the Hunter/Galaxy ones, but the width is lower (I did not have hands on Wild One wheels yet, are they similar to those? If so, it may not fit - need to check further)
Anycase, I'm now sure I will have soon whatever needed to rebuild three chassis. For missing roll bars and rear bumpers, I'm getting those 3D printed...Only  remaining thing to be able to start the project is to wait for body shell availability from TBG. I could build one already, but I don't want to start until I'm able to take one single picture of the 3 sets of parts together (I may need to find a big table to do that by the way)...
The following user(s) Liked this: yogi-bear, stingray-63, Al, 1972 LeMansGT Jim, jord001
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68077
This morning, I found a new trick which may allow me to save on the most damage body shell...
Not sure where the idea came from, but I took my daughter's nails clear paint and just tried something on an aera of the body which should have been normally cut. It became clear again, and I did not even applied on both side. Paint would be on the other side, not sure I should apply this on the other side.
It seems it could work. I still need to try the both side, or only one side and check for possible reaction with the paint... But, that's interesting, and open as well possibilities for the areas of bodies marked with abrasion...
The following user(s) Liked this: caprinut, yogi-bear, stingray-63, 1972 LeMansGT Jim, jord001
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68079
Only for external side.
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68083
Another try with my daughter's varnish.I did clean the chassis and ABS parts, but a white shadow appeared on those which I tried first heavily (it is less the case on the non damaged ones, as I apply a shorter bath, but still some whit shadows are there). I decided to take the damaged parts for a try.
Before After My conclusion is that a clear coat should solve the white shadow. I'll get some TS-13 clear as it would work on ABS to do a very light coat on the parts which requires it...
The following user(s) Liked this: yogi-bear, stingray-63, 1972 LeMansGT Jim, jord001
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68142
A bit of CAD tonight to prepare some chassis reinforcement, mainly where screws are mounted, are very often, ABS tubes are damagedFor motor mount first
Then for rear bumper mounts
Lastly an part that goes around the front body mount support (I saw this broken on few chassis seen on pictures during my numerous searches)
More to go, once I'm able to dedicate some time to this:
    For under gear box cover mounts on right and left side (On one of the chassis, one tube is slightly damage. That let me suspect a potential risk, and I'd like to address it)...
    Another one, which is probably going to be the most complex one, to address the weak point around the steering rod holes in the front area of the chassis...
In short, there is still some work to come, and other parts as well going to Thingiverse once I'll be able to print and test fitting...
The following user(s) Liked this: yogi-bear, stingray-63, jord001
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68146
In short, if you know where to find tapping screws of 4*12 with a step of 1.5mm, please tell me :-D
Try these guys:  www.classicfasteners.com.au/
Probably easiest to email them, rather than try scour thru website.
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68153
As we all know, the original tires became quite difficult to find. On the alternative tires side, identified and confirmed few possibilities for the rear that works:
  • Tamiya Hornet and grasshopper rear tires should work.
  • Kyosho Scorpion 2014 rear tire will work as well, with the probable requirement to glue them (did not tried yet with the inside cylinder, but I suspect this won't work, at least the tire has the proper diameter to go on the wheel). They are also closer to the Marui Hunter rear tire spirit in my opinion (I don't really care about the Good Year branding, specially for the runner car).
There might be other alternatives, the rims diameter are about 4 cm for both front and rear.
For the front, I believe (and I still need to try out) that Tamiya Hornet/Grasshopper/Frog) front tire should work (rim diameter are close).
Marui Hunter and a Galaxy RS too :) 2 years 8 months ago #68172
I printed the samples to check the measurements last night.
The central part is off for 2 reasons (I applied a symmetry to avoid printing supports, I should have applied 2 of them! And one of the tubes was slightly off from a millimeter). The body mount reinforcement is good, and the rear bumper side is also good in terms of measurement.
I got the central part corrected after my day of work and it is now printing (that was not very long to do).
I'm now thinking about the bumper fixation reinforcement. The measurements are good, but once in position on the chassis, they looks like something added with no purpose. This got me thinking and I started to add led lights holder and license plate as well I also remove some material on the lower to make it less bulky... Not sure it is still fitting the initial purpose...
I'm now thinking about adding some lines as there is on the gear box carters... and possibly adding something which would come on top of the bumper fixation. And this is the most difficult thing as this part needs to be positioned before the carters as it comes from the top, and the bumper has to come from the rear... I start to sense what designers are doing when they work to design our buggies... And the good thing in this? It is a lot of fun for my brain :-)
The following user(s) Liked this: stingray-63, Al, jord001, Ducksnuts
Time to create page: 0.165 seconds
