Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67099
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
The level of detail is just stunning Jonny.
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67100
Should have added that the mudflaps are just card ATM, 1mm nitrile rubber sheet is on order :)
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67101
That's crazy Jonny.
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67135
Started on the round lights - first step, making a load of flat square bits to turn down:
Some of the big ones needed most of the centres taking out:
Bits bonded together, headlight cups later went back on the lathe to round the surround edges, rest had strips of styrene added ...
Lenses turned from Perspex rod ...
After polishing:
The following user(s) Liked this: caprinut, stingray-63, Al, jord001
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67139
How did you do to polish so shiny the transparent parts?
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67145
120, 240, 400 & 1200 grit wet & dry paper, followed by Novus Heavy Scratch Remover & hard work on a bit of fleece or cotton T-shirt, then a final polish with Novus Fine Scratch Remover :)
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 11 months ago #67148
Ultra brite result Jonny😁
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 10 months ago #67170
Those lenses turned out fantastic!!
I need a mini lathe in my life..
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 10 months ago #67185
Needed some more brass for the rail/rack on the rear cab, I bought more than I needed for stock, apparently it comes in 5 packs too. This is (only very slightly) interesting as Tamiya WR-02/Wild Willy 2 driver sprues also come in packs of five :whistle:
Thin NBR sheet also arrived so have made & fitted the proper rear flaps:
Not that many details on the front ... note the flat electromagnetic horn at one lower corner of the windscreen :)
The "correct" position for the headlamps is slightly problematic :whistle:  ... have ordered a small LED light bar for the ​​​​top of the cab :)
Hagglund Bv206 Bandvagn / Husky from Kyosho EP Blizzard(s) 2 years 10 months ago #67187
OMG I love this built. I would like to have your skill. It looks so easy with your picts. :y:
Time to create page: 0.131 seconds
