Scratch building scale accessories, + weathering 6 years 3 months ago #48094
Very excellent!!
I am requesting permission to steal this idea..:)
Scratch building scale accessories, + weathering 6 years 2 months ago #48153
I've had most of a re-release Sand Scorcher body kicking around for a while after hacking the bonnet off to use on my "Blue Max" project ( here ), for a wjile I've been thinking it would be good to do something with it - to make it look like a Beetle that's had sort parts scavenged off it & languished unloved under a tarpaulin, and to capture the movement the cover comes off...
Looking through my spares heap, I also found the main portion of the Scorcher glass, rear lights (both white and clear lenses), a pair of used re-re license plates, re-re headlamp chrome (minus the lenses), Blitzer Beetle wipers, a vintage sunroof panel, a single vintage front indicator/lens, re-re mirrors (one broken), a re-re license palte light/cover, and a panel to convert the rear window to the split type ...
What I've done so far:
- sand off the lines on the wheelarches & cut off the abbreviated engine cover (empty engine bay to go in later);
- used the fake window split panel (which was a really poor fit, I don't remember it being that bad when I bought it) as a template & fiited my own;
- Dremelled out the rear lights & fitted them, + the sunroof & wipers;
- started on the front underbonnet structure (lots more details/filling/smoothing/sanding to do);
- taken several mm off the bottom of the window glass so I can do something to the interior - I'm not sure whether to add door cards/seats, or go for a more stripped out look.
Scratch building scale accessories, + weathering 6 years 2 months ago #48154
That's crazy Jonny.
Scratch building scale accessories, + weathering 6 years 2 months ago #48215
Working on the front details ...
Reducing old F-150 Ranger type tyres (both width & diameter) to fit cut down wheels left over from my Pumpkin Low Rider failure...
The following user(s) Liked this: stingray-63, HugoBiermann, goldfish999
Scratch building scale accessories, + weathering 6 years 2 months ago #48216
WOW that’s awesome JR :y:
And now I know what glue to use as a bonus, thank you :)
Scratch building scale accessories, + weathering 6 years 2 months ago #48260
Working on the floor; I know the front isn't supposed to be pointy, but I'm not sure quite how short I need to cut if off just yet. Multiple strips of tape are just there to make a template to cut out the right shape on flat sheet:
Also working on the engine bay (etc) structure at the back:
Lots more detail type stuff to yet to do ...
Scratch building scale accessories, + weathering 6 years 2 months ago #48261
That's a crazy built Jonny.
Scratch building scale accessories, + weathering 6 years 2 months ago #48354
Fiddly compound bits for the floor:
Floor complete (apart from the axle holdy bits at each end):
Underside detail - unnecessary, but I couldn't _not_ do it after seeing frog66's excellent work (www.tamiyabase....d?start=50):
Detail layer on the rear end:
Scratch building scale accessories, + weathering 6 years 2 months ago #48361
The detailing is awesome Jonny. Tjat remind my beetle. :cry:
Scratch building scale accessories, + weathering 6 years 2 months ago #48412
Working on the door details ...
Time to create page: 0.427 seconds
