Scratch building scale accessories, + weathering 2 years 3 months ago #70526
I love that. And the wood effect is awesome Jonny
Last edit: by stingray-63.
Scratch building scale accessories, + weathering 2 years 3 months ago #70545
Last dregs of this batch - all 3 coffins look the same, but really don't work for me or fit with anything else I have so will go on eBay. Jerrycan, gloves & boots I will keep, even if I don't have any plans for them at the moment.
The following user(s) Liked this: caprinut, yogi-bear, stingray-63, Lemsko, jord001
Scratch building scale accessories, + weathering 2 years 2 months ago #70616
I listed quite a few of my recent scale bits on eBay - and even sold one of the canoes :) There was some interest in one of the sleds, the remaining skip & (IIRC) the cones - but absolutely zero for the coffins:D / :(
I've also made another batch of card filter & disposable glove boxes - and started on a number of crates :)
The following user(s) Liked this: caprinut, stingray-63, Lemsko, jord001
Scratch building scale accessories, + weathering 2 years 2 weeks ago #71329
I felt like making some small barrels. I aimed for 1:10 scale 60 litres, but TBH they're probably smaller, I made them as big an OD as they could be and still fit 6 on a pallet, and height waw what looked like the correct proportions to me.
Ends were shaped from 1.5mm styrene sheet, sides are from 0.38mm. Chines are Evergreen half round form.
Initially I planned to make 3 pallets worth, and have an additional 1.5mm disc in the middle for support. It turned out to be marginal whether it was needed, and I also found it difficult to find 3 discs that matched :whistle.
In the end I used most of an A3+ sheet of 1.5mm, all 3 of the 0.38mm sheets I had, and 7 packets of Evergreen strip :blink: but have 27 barrels to show for it. I'd always planned to give them a "well used" finish - some sky blue paint clinging on over rust - so the poor to indifferent quality doesn't matter so much, but having graded them, 6 if not 12 are good enough to finish as "new" I think :)
The following user(s) Liked this: caprinut, stingray-63, AndyAus, 1972 LeMansGT Jim, Lemsko, jord001, Ducksnuts
Scratch building scale accessories, + weathering 2 years 2 weeks ago #71331
Ideal for a scale garage
The following user(s) Liked this: Lemsko, jord001
Scratch building scale accessories, + weathering 2 years 6 days ago #71401
Barrels all ready to be sprayed:
Also felt like make some more pallets, TBH the building takes minutes at most, all the time is in the prep , plus the painting afterwards.
I started by making some 9x14 forms from 3mm sheet, lots of cutting, bonding & sanding later, they look like this:
The se are then chopped into 10 and 14mm wide blocks.  With a load of 10 and 14 mm wide strips from 1.5mm sheet ...
... which make the top ...
 ... spacers stuck on the underneath ...
and the bottom strips:
Repeat until it feels like you've done enough :)
Scratch building scale accessories, + weathering 2 years 6 days ago #71408
Those pallets looks great!
I could not belive how wooden the pallet I got from you, felt.
Nearly the same weight as my balsa pallet as well. feels like it anyway..
Scratch building scale accessories, + weathering 1 year 11 months ago #71540
Barrels are done, ranging from quite smart to pretty rough :)
The following user(s) Liked this: yogi-bear, stingray-63, AndyAus, Al, Lemsko, Ducksnuts
Scratch building scale accessories, + weathering 1 year 11 months ago #71541
wonderful work, i love the painted barrels.
Scratch building scale accessories, + weathering 1 year 11 months ago #71544
They are amazing
Time to create page: 0.186 seconds
