SIlverTriple's 3D printing stuff... 11 months 1 week ago #75483
And the result is here :
Notes :
- stringing is coming from the lack of any retractation in the used profile, provided directly by Colorfabb for Bambulab printers
- 25% Cubic infill is too much for what I want to achieve, but it could be nice for a shelve...
- The tire design is quite simple, and can be adapted to any rims, external dimension and wiidth...
- I thought the lettering would be not as good as it is, so this means that pretty much everything is possible (a world of possibilities).
Next : refine infill to approach targeted shore for the tire on the rim (far too hard at this stage).
SIlverTriple's 3D printing stuff... 11 months 1 week ago #75490
Infill set to cubic-5% seems to be a nice spot. Maybe I should reduce bottom and side walls (there is currently 6, and 3 wall loops) as the sides seems to be slightly too rigid. I'll probably launch another print with 4 or 5 wall loops. The real question I have is to understand is they grip or not, and if they last more than a 5 minutes run on an asphalt track :-)
Time will tell...
The following user(s) Liked this: yogi-bear, stingray-63, Al, Lemsko, Ducksnuts
SIlverTriple's 3D printing stuff... 11 months 1 week ago #75492
interesting resin, keen to see how they go when you run them. Also interesting that is seems you can potentially change the characteristics of the tire by changing some of the print parameters.
SIlverTriple's 3D printing stuff... 11 months 1 week ago #75493
Not resin, this is filament based printing. I Highlighted it in the previous post...
Print perimeter and infill have clearly an impact on the shore... That being said, I'm not sure how they behave when run. It maybe worse than regular TPU/TPE in similar shore hardness...
SIlverTriple's 3D printing stuff... 11 months 1 week ago #75499
yeah silly me, there are is even the stringing in the print, I should have picked up on that!
SIlverTriple's 3D printing stuff... 11 months 2 days ago #75563
I did pursue my tests with the PLA as support interface material for PETG...
And once the flushing volumes are set properly to avoid material pollution, there is no more adhesion issue within the print. Indeed I just bump a bit the flushing volumes before it goes to the purge tower... And it is a success, with a near perfect print...
And it would work as well with PETG as support interface for PLA. That being said, I did not succeed to do the same with part where most of the surface lies on a PLA surface (exemple the Shogun battery door), as it warps due to the difference of material temperature: this for sure requires more work.
The following user(s) Liked this: yogi-bear, stingray-63, Lemsko
SIlverTriple's 3D printing stuff... 11 months 2 days ago #75564
And just because it maybe usefull to one who wants to try...
Here is my flushing volume settings for this print. PLA White (Bambu Lab) is 1 and PETG Orange (Sunlu) is 8 in the chart.
SIlverTriple's 3D printing stuff... 11 months 23 hours ago #75576
It's crazy how far 3d printing has come.....  A few years ago, wouldn't have thought it possible to print tyres!!!!
SIlverTriple's 3D printing stuff... 10 months 4 weeks ago #75579
Indeed.
SIlverTriple's 3D printing stuff... 10 months 3 weeks ago #75681
After the PETG / PLA combination, I wanted to adjust the settings to be able to do some difficult ABS prints, using HIPS as support interface... I did initial testing last week, which were quite unsuccessfull as there was some mix up in the filaments printed, causing some key adhesion issues...
I did set the purge to 600 instead of 500 mm3, and it seems much better... There is still a bit of adhesion issue on one of the tabs to fix the battery plate, but we are getting close. And since they work at the same temperature, there is no warping issue...
That said it is not perfect yet, and I may decide to use full supports printed in HIPS in this configuration, it may be easier to detach, all the more so as, there is some dissolvent that works for HIPS and that doesn't dissolve ABS...
Time to create page: 0.225 seconds
