Do you use a RC car stand to build your car or truck? I have three of them. The Black & Decker is still my favourite one. The round one is the second which I built myself. The base is a cast iron flange bearing. The worst of the three is the TFL which is too lightweight and not really stable. The turntable is attached to a bolt that goes up or down when it turns and it will stop turning when the bolt thread is at the bottom.
Last edit: by yellowcat.
My rc are built on the living table and my legs and my statics on the table. I had my own stand but no more since I changed home.
But I am thinking to use my lidl workmate with a larger upper plate and my mini rioby on it. |
Last edit: by stingray-63.
I just don't see the point, if I need to elevate a chassis a few inches or rotate it I can do it by hand, and it's not as if anything (like 1:1 exhausts, brake & fuel lines, brake discs) is going to get damaged by sitting on the bench ...
If someone wants to play "garages" while building/maintaining an RC car then fine - but surely scale trolley jacks, axle stands or even a 2/4 post lift would be better? ![]() |
1/5 cooooooolllll.
I don't really see the point in them as they have never really been necessary to work on. I usually use mine for keeping my tires of the shelve and when washing motors as I just sit a jar next to the stand and drop it in. My stand is a piece of cardboard foundation tubing cut down. 2 dollars at any home fix it shop.
Actually I can think of a situation where a well designed car stand would be very useful - installing and testing electrics. it would have to be heavy and stable, or clamp down, and you couldn't rely on gravity or friction to hold the car down (vibration, inertial or CoG changes mean it could drop off & accelarate off across the bench), you'd need some sort of tie down, and adjustability front to rear and side to side ...
True but the same could be said for a standalone motor tester... is there really ever been ANY situation in your RC world were you have said " badword I can't do that because I need a stand "?????? I surely never have.. .
Keep cool buddies. Everybody does how he wants.
