Mine is out. The chrono is hs, the tx doesn't work and I think that I flashed the rx. It is in the tfe for the shelf. And if I want to run it, I use the ko I have in the egress
no it doesn't work. But it is still in place and soldered. On my two adspec, I gave you the only one worked
I got the Alfa! (yay) bad stuff first, seller didn't removed antenna tube before it going in the box, so I have a nice crooked antenna tube:whistle: luckily I have some antenna tubes fooling around (Since I have this thing for using 2.4 Ghz on new models), the another thing is that red parts are obviously cracked (Release the Cracken!) I remember new parts from ebay tend to not crack in at least a year, so, not an issue would be soon solved..
Controller is an Acoms Techniplus, with acoms rx and servo, are acoms stuff Futaba compatible? (mainly wiring) |
Last edit: by Dash_Crash.
Nice stuff Dash. Red parts were too tighten. And yep the wiring is the same between futaba and acoms. Acoms connectors could be a little too big but not sure on yours.
You have pretty celica 2 parts rims too |
from where are they? I want the same....
