Yes ... but no. The "FF" there means "Front engined, Front wheel drive". Check out the 58149 Mini Cooper ... M-01 chassis, but it also says "FF" on the manual cover |
True enough... and I guess that's typically Tamiya.
They must have made a separation at a later point then. I just discovered something else that's not quite on topic but it shows the same pattern that often happens with Tamiya. The Manta Ray (and many many models after that) uses the TG10 wheel axles. Only that was released two years later... The axles had alraedy been produced for quite a while when they decided to make it a universal part. Giving the name to it when they made that change, not when they were first issued. They should be called "Manta Ray wheel axles" if you look at the time line. Only another part number makes the distinction... |
With another Tamiya twist... the kit supplied number is 2595074.
For the Top Force kit supplied is 9805369 - same as is listed for the Manta Ray spare part apparently. More or less what they did with the pinions btw. I looked at earlier models but the 58087 was the first car to have the part. Not really TG10 wheel axles one could say... But retrofitting, or rather retro-categorizing is a well know Tamiya phenomenon. Noticed it in the CVA evolution also. |
I've had a look at the FF01 and M chassis both being called "FF".
The first FF02 actually has "FF02" on the first page but at the same time the M cars are also still referred to as "FF". First one that's called M (that I found so far) is the 58295 M03L. They didn't switch immediately after the FF02 was released. The first few M03s are still FFs in the overlapping production period between both chassis. Officially it's M-03L btw, but the use of "-" is also a conundrum. |
Found what I'd previously researched on the "FF" chassis :
Looks like the guide books are a better source here, although I cannot say the logic is obvious...
Makes the info in the manuals even more peculiar when the Ms had a designated type early on. |
I noticed the Japanese guide book already lists an FF01 and FF02 since the latter came out in '99...
www.tamiyabase....html?pop=0 The logic in the guide books and manuals seem to match that way. M chassis is a different story though... |
Other Tamiya abbreviations could also be nice to add to the list, but I'll stick to basic chassis types for now.
I think we can agree "FF" stands for Front wheel drive Front engine - to be a bit more specific... And there's other chassis of course : DN Dirt ... F Formula GB (TamTech) GT (TamTech) NDF Nitro ... TG Touring Gasoline ? (quite a few TG chassis with additional letters) TRF Tamiya Racing Factory Together making this list : XC Xross Country
CC Cross Country
XV Xross Vehicle ?
DB Dirt Belt
DT Dirt Two
DF Dirt Four
DN Dirt ...
F Formula
GB
GT
NDF Nitro ...
WR Willy Ranger
CR CRawler
TXT Tamiya Xtreme Truck
TLT Tamiya Little Truck ?
TA Touring group A
TB Touring B
TL Touring Light
TT Touring Trainer
FF Front (wheel drive) Front (engine)
M Mini
TRF Tamiya Racing Factory |
