Grasshopper resurrection - body shop 10 years 11 months ago #22229
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Cheers guys, building this one's really a trip to memory lane. :)
I'm just working with the stuff I have at hand, I would've had a go at doing the shell with plasticard and styrene glue otherwise...
Not that I'm complaining about the strength it seems to have acquired now.
Looks messy still but I can already see it being a feisty red Hopper.
:pinch:
Grasshopper resurrection - body shop 10 years 11 months ago #22240
  • Edou
  • Hopping Mad
  • Hopping Mad
Man, that rear axle dampening works nicely already. :)
Grasshopper resurrection - double shock mod video 10 years 11 months ago #22243
  • Edou
  • Hopping Mad
  • Hopping Mad
It's even adjustable (in hardness) 'cause a screwdriver can reach the shafts from the top (through one of the holes). :cheer: :silly:
Grasshopper resurrection - double shock mod video 10 years 11 months ago #22251
Very tidy :cheer:
Grasshopper resurrection - more body work 10 years 10 months ago #22518
  • Edou
  • Hopping Mad
  • Hopping Mad
Decided to glass fiber reinforce the nose...
Tip was done separately here but the whole surface will get the treatment, new approach is to pour the resin on the fiber mats :
Hoping to achieve a smoother surface like that, which would mean much less sanding :
Some extra fibers on the sides and going for an additional bit of reinforced surface :
Smoothening out - after lots and lots of sanding (no images of that) :
Front end had a piece missing that's fiber glass now :
Starting to look alright :
More coming when the rain stops...
Grasshopper resurrection - more body work 10 years 10 months ago #22523
:) Very good idea it will be fatter and good for the direction :y:
Grasshopper resurrection - more body work 10 years 10 months ago #22524
  • Edou
  • Hopping Mad
  • Hopping Mad
Shell really was a bit flimsy there. Couple o'cracks too. Gonna do the roof the as well. :)
And then figure out a good way to fix the missing piece on the wing...
On another note (so I won't have to start a new topic) - anybody know a good alternative 18 teeth 0.8 module pinion?
Brass originals are quite expensive and apparently the one I got is alloy. So that's a ninja star by now.
Grasshopper resurrection - more body work 10 years 10 months ago #22525
  • Edou
  • Hopping Mad
  • Hopping Mad
Bit of primer on the outside to see where I'm at. Going alright :
Grasshopper resurrection - more body work 10 years 10 months ago #22526
sterling effort on the body starting to look very nice :y:
Grasshopper resurrection - more body work 10 years 10 months ago #22530
:) If you remove the 540 adaptor, You can put a hornet pinion in aloy :y:
Time to create page: 0.196 seconds
