Some very interesting suggestions by darc... I'm just not sure what you mean exactly with no 1. Could you elaborate? Does that help spread the tension? The second suggestion is definitely also very interesting. I'll keep that in mind for when I decide to go off road jumping... No 3 I have approached myself in another way. Of course the best way to solve this is an FRP chassis and a Top Force steering assembly. But I have modded a reissue chassis also to fit alloy steering parts and a threaded shaft instead of using tie rod BP7 : Not without consequence though - a big part of the front of the chassis had to be dremeled and weakened as a result. But I'll be using some fiber glass and resin to strenghten it again. Gets rid of all the play! |
yes number one keeps the pressure on the casing more suffecient , i discoverd this problem with a ten turn double brushed motor and 5300 nimh batt and a tuff race course .
but outstanding work hats off to you with the steering never fantastic job i am going to follow this tip and replicate it on my manta ray well done
Still quite amazing how this "old" design manages to handle with that kind of power.
Should be loads of fun with a 13.5T brushless... and some spare parts. An even nuttier idea would be to fit some high quality universals and a 10.5T. Don't think the dogbones and cups will hold out long with that... |
heheheh oh they will handel it matey , this car is the first of great design and put the terraschorcher chassie out the racing scene .
however as weird as it may seem i have actually found the orginal geared diffs more stronger and more lasting than the ball diffs . i pack all my geraboxes and diffs with high content molybdenum disulphide grease , i pack them so hard that on the first motor power up the grease actually slows the motor down for a short while while the grease adapts to the internal dynamics of the gearbox and motions of gears etc . |
My Projects:
